Badger1bear
If your not on fire, then your too far away
- kent
hi guys, I’m one of the old skool welder fabricators, a bit like @8ob (I’m still uncertain of how to tag people in posts)
This post is about what tips and tricks you use or you have found in vids online for manipulating metal. Not necessarily using heat. Pretty much it’s looking at metal thicknesses of 10mm and thicker. I have found a channel on YouTube where some Russian welders use a C shape which is welded to one of the two pieces they need to move and drive a wedge inside the C to move the metal. Another way I have found and use is to use large threaded bar and weld two L shaped brackets to the parts I need to bring together. Winding up the nuts can give you a precise fit
What tricks have you picked up over the years ?
