MattF
- South Yorkshire
Just wondered if anyone had a recommendation as to a good metal cutting blade for a padsaw/keyhole saw handle. Half the time I just tend to fit a hacksaw blade in there and use that, but wanting to cut a fairly tight curve in 3mm or so steel, so I know the hacksaw blade wouldn't be a good choice. Wanting something with a bit of rigidity but slimline.
The use it's for is to cut the mounting plate from the top of a vertical air receiver. Wanting to cut it so that it leaves domed mounting lugs where the four weld points are, so that I can add a fixing plate to the mounting plate to bolt it back onto those lugs, so I obviously want to keep the cuts quite neat.
I'd not considered jigsaw blades. I've got some knocking about somewhere. Doubt they'd hold too well in the padsaw, but if I could find/make something to hold them, they would probably be spot on.
