Windy Miller
Semi-Professional Potterer!
- North Kent, UK
Evening All!
I have a scruffy old E series Merc Estate with a 3.2 straight 6 TD. Nothing at all to look at, but a lovely car to drive, and (compared with my L200) fairly economical to run. It's very comfy, surprisingly fast, and has loads of room. A while ago, it developed a problem though.
Driving it late one evening, I heard a noise which sounded suspiciously like a belt flapping about. Sure enough the serpentine belt had shredded. One of those poly vee things with grooves that run all round the belt.
A few hundred miles earlier, I had changed the belt, the generator pulley (one with a clutch), the tensioner and both idler pulleys. So I'm wondering why the belt went so soon.
Pulley alignment was pretty good, with about 1mm runout, and everything that the belt drives all rotate nicely with no nasty bearings. Bottom pulley sound, water pump and power steering pump pulleys all good. Everything seems good, apart from the air con pump pulley, which had some belt debris embedded deep into the grooves.
I'm wondering if maybe somehow the pump seized and the belt slipped around the pulley for a short while before it broke? The pulley rotates freely now though, as does the centre shaft so if it was seized it's not now. To be honest, I'm a clutching at straws here, as I'm a bit stumped as to why the belt broke, and the seized A/C pump is all I could think of. The belt was a Gates one, so I doubt it's just a dodgy one.
Andy ideas?
Andy ideas?
