the problem is that you would be using the regulator at 22% over the maximum pressure it is supposed to handle. I expect there is some sort of safety margin but I wouldn't feel happy about using it that much over and if this is for business use you should definitely get something rated to the compressormax pressure is only 123psi
Yes it will accept a lot more but that is the most it will output.Are you sure that's the max safe working pressure the regulator can handle and not the maximum pressure that the regulator can be set to output?
Just a guess as most compressors seem to be set around 150psi from the factory but 90-110 is the standard for tools
I'd imagine that pressure will be fine for blasting, it's the flow I'd be more concerned about. Even the biggest blasters will work fine at 90psi as long as the cfm is high enoughYes it will accept a lot more but that is the most it will output.
I managed just about before with a 14cfm 3hp compressor. This 7.5hp should be a huge improvement.I'd imagine that pressure will be fine for blasting, it's the flow I'd be more concerned about. Even the biggest blasters will work fine at 90psi as long as the cfm is high enough
Reg says it will cope with 4000lpm so should cope no problem.I'd check the cfm of the regulator and if it's less than 14 cfm then fit two parallel or go for a bigger unit
Yes I know they are joking figures bit should be more than double my old setup. I could couple the 2 together I suppose. Will see how it goes.As mentioned (on another of your threads?) you won’t get 14cfm @10Bar, from a 2.2kW compressor. But 7.5HP will be an improvement on the 3HP one.
