Shox Dr
Chief Engineer to Carlos Fandango
- East Yorkshire
Reading on another forum, about a guy wishing to build a setting out/welding table. wondered how to make out the grid and drill Quote "I will be using a waterjeted layout jig to transfer punch all the hole locations, but does anybody have any suggestions on how to line up the mag drill with an annular cutter over the hole location after I have transfer punched it? I could always change out the cutter with a drill chuck, use a center finder to make sure I was lined up....
Is so happens I building a table as well and have given the marking out and drilling of the grid, some thought and the best I have come up with so far is.
Clamp bar to longest edge, drill 1st hole then using a milled sq former to the dimensions you require C-2-C less half the distance to the centre of the mag, and the diameter of the hole you are going to drill.
Then placing a pin in the 1st hole and butting and clamping the former sq to pin and bar. You can then cut the next hole, etc etc. Once the first row has been drilled place pins in the holes and butt the bar to it, the next lot of holes can then be drilled. Remembering the former will have to be modified to take into account he Pin dia, and bar.
Hopefully at the end, the table will have a sq grid.
If that makes sense.
Any comments/suggestions
