The Z'eer
- Essex
What I've done in the past is wrap the form work in visqueen so you get a lovely smooth finish to the vertical face, the easiest way I've found is to pull the visqueen tight around the wood formwork and staple it in place anywhere except the face that will be against the concrete.
I did that with the membrane on the main slab, purely by chance was the result since I lined the formwork by mistake.
cheers for the tip, I'll use that!
