knoba
...break a leg!
- Sussex, England
I'm after a decent magnetic drill and I think it comes down to one of the two below. Does anyone have any experiences with the dewalt? I've read some good threads on here about the Rotabroach one and know a lot of trusted members use them.
Having never used a mag drill before; do they take side loads well?
Can I get a drill vice (& material) easily underneath them?
Quill depth on the Cobra?
Rotabroach Cobra
DeWalt D21620K
Rotabroach Cobra
- 6 month manufacturer's warranty
- Drill on site or in a workshop
- Cuts holes up to 65mm diameter x 50mm deep
- 1400 watt motor
- Feed capstan may be reversed for easy positioning in tight areas
- Controls mounted at the rear for better access
- 1200 kgs magnetic adhesion
- Variable speed - the right speed for the right diameter
- Automatic cooland bottle
- Supplied with secure carrying case
DeWalt D21620K
- One year warranty included with this DeWalt D21620K.
- The DeWalt D21620 K is a compact and light weight unit which is both easy to transport and easy to position for drilling.
- Delivers high level of performance for fast, clean and accurate drilling into steel.
- Push button reversible press handle offers tool-free handle set-up.
- The universal quick release cutter holder is quick and easy to operate : no Allen key needed. It accepts any annular cutter with 19mm round shank (Weldon) with one or more flats.
- 3 seconds delayed magnet release avoid drops if the power is cut. The drill will also not restart automatically when powered is restored in order to deliver more safety.
- 2 mechanical speeds for optimized performance.
- Power Input 1150 Watts
- Spindle Thread 1/2" x 20 UNF
- No Load Speed 350/650 rpm
- Cutter holder 19mm Weldon shank (3/4")
- Max cutting depth with cutters 50 mm
- Max cutting diameter with cutters 50 mm
- Drill point pressure 317 Kg
- Clamping force 10000 N
- Length of drill stroke 147 mm
- Weight 13 kg
- Magnetic base dimensions 180 x 84 mm
Very informative indeed. What did you decide on in the end? It's a rather specialised bit of kit for an enthusiast (meaning myself). Justifying it is difficult, especially when one considers that, once bought, if it's a really useful tool it often finds a 1001 uses. Add to that, that if it is such a tool, buying a cheap / low spec machine is always, sadly, lamented.
