BrokenBiker
- Newport, South Wales
hi all,
hoping for some knowledge here
as most of you know i run a sealey 100amp gasless.
while using it this morning, from the first time i pulled the trigger, to the time i finished about 20 mins later, i couldnt help but notice the sound of the arc is much louder, but still sounds like a normal weld, just much louder, and also the wire feed motor was much louder too. at first i put this down to the fact i was sat on the floor welding, and it may have been echoing off the very close walls, and floor, but even when i stood up and put the welder on the table, at the height i usually weld, it was still loud, regardless of voltage or ampage.
the wire is the same reel as i have been using previous, fairly good quality, nice weld, and good slag coverage, still 1/2 to 2/3rd's of a reel on there. i run with no shroud as i have no gas, and the gas outlet on the torch has a rubber seal in it anyway, and my tip looks ok, although i doubt its the tip or shroud thats causing it. the wire isnt snagging, and feeds smoothly, but its just so loud. even with earplugs in it sounded louder than normal.
any ideas on what is potentially wrong, or am i just not as deaf today as i have been
could it be that i havent done any grinding before hand and my ears havent been destroyed before welding, so i can hear it better?
although that may be a while as its sunny and beer is calling
