Bladevane
- Harwell, Oxon
As per the title but first a litle background.
We upgraded our gravity fed water system last year to a pressurised system which included a Joule Unvented Slimline Hot Water Cylinder, expansion vessel and all the trimmings. The installation was done by a pro and was so much neater and compliant than I could have achieved. It works perfectly.....but...has always exhibited a loudish "crack" when the water pressure decreases, like when the shower thermostatic valve is opened. The pro said not to worry. As I said, the system works perfectly and there are no leaks. I am still concerned that the cylinder is going through a cycle of pressure and therefore demonstrates this as a noise, a variance which is not something I am too happy about. After all, a cylinder is a static device and should not move, unlike a dynamic device which I would expect to grunt and groan a bit.
My question is, therefore, has anyone experienced similar noise and what was done (if anything) to eliminate it?
I have tried various pressures in the expansion vessel and the cylinder from 2 bar upto 3 bar. No difference. The cracking noise can only really be repeated when the system is isolated and the pressure drops to zero. Otherwise it's a bit random.
Thanks in advance.
Thanks in advance.
