Hi All
I have just purchased a clarke 135te to tackle some repair jobs on an old land rover. I am using Hobbyweld 5 argon/co2/02 as the shielding gas.
I am totally new to welding and have been practicing on the work bench with scrap metal and had some good results running beads and joining bits together.
I have actually managed to weld on a couple of outriggers quite successfully but am really struggling with thinner metals in the footwells.
They are approx 1.5mm thick and I have set the welders power and wire speed as per the clarke manual for that thickness of steel. The existing metal has been cleaned up with a flap disc and is as clean as I can get it.
Gas flow is approx 10-12 litres per min. Is this right for this kind of work? It seemed good for the thicker chassis/outrigger work.
When working with the thinner metals I am constantly getting the weld "balling up" on the joint and it looks like I am placing metal balls on the surface. Also a lot of black deposits (carbon?) around the weld. I have tried varying the wire speed and gas flow but just can't get a good clean weld. I have tried changing torch angle and also torch distance from the surface. Brand new welding tips in the torch.
Any advice welcomed, many thanks
