Tried to use the machine today, gas ok to it none from it, Discounted the torch as there is nothing coming from the machine with the hose disconnected. Any thoughts guys.
Probably the gas solenoid valve packed up, if its working you can here / feel them click when the triggers pressed, its usually an easy fix to replace them, worst case is that the valve is ok but the machine is not sending a feed to it, which may indicate a board fault, a few minutes with a test meter will soon tell you.
open the machine up, find the valve that the gas hose goes into and check if there any coming out when it should be. If not then either the valve is dead or tthere is a bad connection
