Hi all.
I recently fitted a Dinse 10/25 panel socket to my first welder, and all seemed well. Attempting to secure the internal lead to the second panel socket I purchased follower however resulted in the front plastic portion breaking on me.
Then when it came time to use the welder the Dinse panel socket which looked okay would spin around when I tried to secure the return lead into the socket on the front of the welder. I would sometimes need to open the case side access and hold the cable inside and faff about with it until I could get the plug on the return lead to "lock" into the socket.
Matters were not helped by having very limited access where the panel sockets are mounted, making it difficult to properly tighten the set screws which secure the leads internally.
Would anyone have any suggestions on what I could try to improve the situation please? I'm nervous about over tightening the socket and breaking another one, although having it loose as it is atm isn't ideal either.
I've been using 25mm reusable cable lugs, which don't fit over the threads at the back of the panel socket, but appear to be held by a washer at the back of the threads with the set screw, not sure if that's standard or not.
Many thanks for any help and suggestions.
