steve.hall30
New Member
I'm looking to weld some stainless steel (304L) woven wire mesh, like this stuff (http://www.inoxia.co.uk/rw/category/9.aspx to a stainless steel frame.
The wire mesh ranges from 0.9mm (20SWG) wires spaced every 6mm, to 30μm (49 SWG) wires spaced 400 per inch, and everything in between. The frame is likely to be something like 3mm flat bar, or 1.5mm walled box section (30mm box).
So, questions:
1) I'm sure the 0.9mm wires will weld to the bar or box with no trouble, but how fine could I really get away with, surely you can't weld a woven mat of 0.03mm thick wires?
2) What sort of technique and set up should I use on the welder? I don't own the machine yet, but thinking this one should have the right selection of dials to get something to work. http://www.r-techwelding.co.uk/welding_equipment/Tig_Welder/Tig_Welder_R-Tech_Tig200PDC
I did manage to work out today from research, that a laser welder would be ideal, and that they cost a pretty penny, so looks like TIG is the only affordable choice.
I will really appreaciate any advice on this tricky weld.
So, questions:
,i do know the rods weren't cheap.It may be an alternative to consider ?...
