depends on what size u are after and if the machine is belt drive and there enough room to acomondate the larger single phase motor it wont be a problem. rule of thumb is smaller machines fetch good money and hard to findim on the look out for a single phase milling machine second hand am i better looking for a 3 phase and converting it to single i dont mind travelling for the right one any advise would be great
larger 3 phase machines are abundant and cheaper and can be run of a phase converter
is your inverter 415 v star stormin or 240v delta used on dual voltage motorsGet yourself an inverter, variable frequency drive type, as big a rating as you can.
I've got one rated at 3hp, set-up to run three different machines, mill, lathe and pillar drill just not all at once.
Almost infinitely variable speed and less messing with belts.
240V delta. I had to rejig the wiring on the motor in the Colchester student lathe and Meddings Pillar drill.is your inverter 415 v star stormin or 240v delta used on dual voltage motors
rite240V delta. I had to rejig the wiring on the motor in the Colchester student lathe and Meddings Pillar drill.
Milling machine required a motor change for the main drive and internal surgery for the feed and coolant motor.
I've got the inverter output running to a five pin three phase socket and just plug in the appropriate machine I want to use at the time. Stop/Start, Forward/Reverse and speed selection is run off a small wireless remote handset.
The 415 advanced inverters are better but much more expensive.
i use the static converter at 415v on my mill : because it has a 415 v transformer to run the contactors and i couldnt be a r ./././ed to alter the wiring and change the contactor coil and change the links on motor to run on 240 delta
ritei use the static converter at 415v on my mill : because it has a 415 v transformer to run the contactors and i couldnt be a r ./././ed to alter the wiring and change the contactor coil and change the links on motor to run on 240 delta
i knowUsing an inverter you should bypass the switches and contactor anyway and run wiring straight to the motor. Inverter controls start-up and over temp/current limits etc.
as said cant be a././sed
plug and play
