discotroll
New Member
Hi -
I hope I've put this is the right section but if not hopefully admin will see it put in the right place.
I'm working on a one-off project and I need to cut out a couple of long lengths of steel plate - plate is approx. 9mm thick and each cut is roughly 18m in length. I need these cuts to be as straight as possible so although I'd normally immediately think of plasma I have also seen some online vids of people using a cicular saw (run along a piece of angle) to give a super-straight and clean cut.
As this is a bit of a one-off project I'd be interested in the thoughts of the experienced forum regulars and hopefully get steered in the right direction regarding the best cutting method.
Thanks in advance,
DT.
Thanks in advance,
DT.
