BrokenBiker
- Newport, South Wales
what would you say is the logical way to learn tig, with the intent of getting good at it? not good enough that you need to rely on your skills to put food on the table, but good enough that you trust your welds and that your welds could get you a decent reputation?
my thoughts on it were its best to start off on 5-6mm steel, no filler and just run back and forth to get good with arc length, then move onto adding filler on flat welds, then onto butt joints, lap joints and fillets all in flat and horizontal positions, then vert up and down, and finally overhead if that sort of thing takes your fancy.
then after that move onto ali and do it all again, cut and etch test joints, destructive tests etc until you are confident
