zx9
- South East London
This is true however the small bore tube 5mm ish internal is less than 500mm and has the direct path through the T so not going to be a lot of drop, probably less than in your measured pressures from the internal compressor which uses the side of the T and has to pass a 90 deg. turn.4.5 Bar is the maximum rated input. There would be some pressure drop by the time the air gets to the torch connector, dependent on the amount of tubing between regulator and plasma cutter, and on the regulator itself.
