shenion
Tool Pack Rat
- Stone Mountain, GA USA
Above is the thread block from by 6" vice. The center bolt hole is stripped.
The block sits inside a 2.5" square tube. No way to fit a MIG gun in there.
I had just gotten the Airco working and some nice Fleetweld 7018 rods. So I decided, why not try these new 7018's
As there is only 3/4" clearance on each side, I had to have the rods near flat for most of the weld. As I got closer to the front the angle was better and I actually got some penetration/fusion. Did some real nice beads on the front third. Slag came off easily. Could have use a bit more power, but was undercutting the weld as is.
I welded the front first and the block had raised ever so slightly in the back. Made the vice real stiff as the threaded rod did not turn easily.
The back foot was accessible at a steep angle through the bottom. Looks like a bit of slag inclusion (shown at arrow.) Rod had to be done at near 90 deg from joint.
Lasted about 6 months of abuse. Pulled it out it and it is a perfect example of embrittlement. The weld is fully crystallized and looks like sand.
The back "foot" is the important part as that holds the main force.
I'll get a longer bolt to use more threads and weld the back edge with 309 MIG wire. I can get to that easily with some grinding of the hole. I might be able to do the front too. Hard part will be grinding off old weld, it is very hard.
Another option is to get my O/A refilled and braze it. But will also have to get more brazing rods.
Would not have had these problems if the block had fit better from the start and the bolt was longer (only had about 1/4" of thread into block.) Cheap vice, but don't have the $$ to drop on a real one.
