flash of light
looking at buying a diesel 100hp ish polo or leon to use for getting to work i wondered if any of you may have owned one. im going to then weld up my discovery so its sweet to sell.
im also going to look at buying a series landrover. i cant live without 4x4.
Have got diesel Fabia 100 pd, this is polo based. Done 188k miles, with no probs other than bushes on front lower bottom arms. Poly bushes better but still change them every year. Same clutch, engine, gearbox, alternator belt and have never needed to top up header tank.
Dear CTB, oh yes, most definately changed timing belt and tensioner regularly at 55k instead of 65k interval. Wife's octy was 75k interval!!!
Took it really easy to work, driving with the instantaneous consumption display reading as high as poss at all times. Got an average of 79.7mpg o/all.
Did the same on way home and average of 74.3mpg o/all. Thought that was ok, can get better figures in summer. The route is NOT flat.
Mind you, it was bloody boring!
as you might allready know you get better mpg in summer because less air molecules per square foot to move out the way, as the molecules ar larger in the warmer days.
Agree with flash of light. You're correct with intercooler lower air temp etc.
In deep winter (-10*C) my car takes ages to warm up, unless I gun it.
My Skoda mechanic tells me extra fuel is admitted during warm up to make engine run sweet. Its then turned off.So easy driving or gunning it, it's still costing more fuel than summer. Diesel engines need to be warm to be most efficient. Add demister/heater/rear demister/door mirror demister, light cos it's dark when i go to work in winter/wipers, it all takes energy/fuel.
