Never seen a l/h drill....is it morse taper?,can imagine chucks would be a pain ,have you got lots of drills?
I would like to have the option of using left hand drills in my pillar drill, what would be involved to do this?.
TIA
Gav L/H drills are normally for removal and extraction work, IE studs, broken taps drills etc, often made of col-bolt or similar hardness, i use a fair few and nine times out of ten there salvage a job without extreme measures, and yes chucks can be a pitta...
....don't have much call for extractors,if its broke ,its broke due to a large spanner trying to undo it and if i can, i hit it with a mig and nut let the heat do its work
..or drill and re-tap...will have to do a search and see if there are decent makes other than JML?....
just make sure your drill chuck has taper on it and not threaded on . otherwise it will unscrew its self![]()
