Nigel B
AC Idiot & DC Owner (& Idiot)
A Miller Laminated TIG Guide
A plastic coated 4 x 9 inch calcualtor with a slidey laminated card inside.
This will allow you .....(or me)...... to see the settings for 'TIGging'
For all the the above you select either
and
The thickness of the steel etc you welding
It then tells you
A little godsend for idiots learning like moi
Here at £1.50 inc P&P :blink: from Miller : Welding Guides
Arrived a fews days after ordering, its superb ....consider getting one
They do 'set of MIG TIG STICK' or all sepeartely
Nige
- Stainless Steel
- Mild Steel
- Aluminium
- (And if your nuts Magnesuim and Titanium)
- Butt weld
- no not that sort
that sort
- Corner Weld
- Lap Weld
- Fillet Weld
and
It then tells you
- Tungsten Size for torch
- Cup Orifice size for shroud
- Filer rod size
- Amps
- Gas Type
- Flow for gas CFM
- Flow PSI
- Expected TIG weld speed per inch per minute
Nige
