I would like to get myself a lathe, it cant be anything too huge as im limited by only having a single car garage to house it, it will also need to be 240v volt, i was thinking perhaps a myford, budget wise £1000 would be the most i could afford to spend, what small lathes are worth considering and what should i look for when viewing a lathe, a friend has offered me an ML7 which he assures me is good but i need to know what to look out for
things to look out for are wear on the headstock bearings /wear on saddle and on the cross slide . also check that theres not a lot of backlash on the feed screws. eg they shouldnt turn half way round the dial back and forth without moving the saddle or cross slide
basicaly make sure it hasnt been caned and abused
.....boxford,harrison L5/140..etc etc don't take up much more space than a myford...the mass of the machine can make a huge difference,,and the bore through the spindle allows for larger material and deeper cuts etc....
