Have seen this lathe not too far from me, can anyone tell me what it's worth by the description, also are parts readily available at reasonable cost. Bear in mind I know sod all about lathes.
Thanks
Drummond b type ,about 100 year old ,going by number stamped in bed,,it is working ,but needs setting up better ,I removed back gear to change belt and couldn't be arsed to put back as I dint need it,,has V bracket and change wheels for auto feed if you wanna set up,,,,wired with f/r switch,,when switching on sometimes need to help it start,,motor runs it fine ,,,can help to dismantle and load
Thanks
