Munkul
Jack of some trades, Master of none
- Cumbria
I don't have anything but carbide tooling. I have a couple old HSS tools I'm keeping for just in case i need a special form tool, but for general turning... carbide inserts all the way. Especially if you've got some money to put into it and you intend to make it pay for jobs.
The critical thing is inserts. You can get negative rake inserts that perform beautifully on light cuts, just the same as you can get positive rake inserts that perform terribly... and vice versa.
Same with interupted cuts. I've had horrible square interrupted cuts in EN24 steel that just about shake the lathe... but didn't break the insert... because i was using the right insert.
Nose radius is a kind of good indicator. Grade is another.
My favourite two external tools are a CNMG and a DCMT. The CNMG I have all sorts of inserts for, from specific roughing inserts, down to extremely delicate finishing inserts.
The DCMT I have finishing inserts for steel and also for aluminium.
Cheap inserts are a waste of money. My favoured approach is to search on ebay for NOS inserts from Kennametal, mitsubishi, quality brands etc, and work out what sort of work they would be best suited to. When I was still learning all this stuff, I made mistakes, but i also ended up with a load of roughing inserts which are great for farmer-y type jobs.
Don't anyone ever tell you you need speed to run carbide... you don't, you just need the right depth and feed
