max bayliss
New Member
- weston-super-mare, UK
Hi all
New to posting on the forum but have viewed many usful posts in the past in the past.
I have an axminster C4B lathe that has been working very well up till now.
i was doing some thread cutting this after noon and i went to reverss the lathe and got nothing but a buzzing sound.
i stopped it and tried again and it reversed fine, did another cut and it did it again, this time it never started again.
the motor works in the forward position still but dosnt reverse at all now.
After stripping it down a to do a bit of testing i found that if i spin the motor in reverse and turn it on it does run at full speed if i stop it and try turning it on it wont run. i have a look at both the capacitors on the motor but they habe no connectors and are hard wired i was going to swap them around to test. not sure if taking the motor apart will give me the chance to unwire them.
anyone got any ideas what may have died? i dont think its the winding as it still turns one way. im not sure how the centrifugal could be the problem but my thought is it wouldnt work at all.
Any one got any hints tips ideas of what to do. a new one is looking around 100 GBP so not keen on that.
motor spec is.
single phase ac induction
Type YLA 7134
No: 1100615
550w
240v
3.8amp
c1 100uF 250v
c2 20uF 450v
1400rpm
Rating: S1
motor spec is.
Type YLA 7134
No: 1100615
550w
240v
3.8amp
c1 100uF 250v
c2 20uF 450v
1400rpm
Rating: S1
