I'm in need of some mild steel laser cut components which will vary in thickness between 12 and 25 mm thick. (could be water jet cut) . I'm only after a few bits at present. Does anyone have any recommended sources in Essex ? I'm based near Brentwood so the nearer to home the better. I would need the cutter to have the plate, work from an engineering drawing and be amenable to doing just a few components. The few that I've approached aren't interested in this type of work.
