H h-magic Member Messages 30 Aug 28, 2009 #1 Hi just a quickie can you just re-laquer a pannel without rubbing it down? I sprayed a bootlid yesterday and there was not enough laquered put on it. So I want to put some more. How would I go doing this.
B buybuybuy Member Messages 11 Aug 28, 2009 #2 You would need to scotch the panel up first of all or you could use some p800 wet and dry to key the surface up. When you put the lacquer on apply a thin even coat and wait for it to go tacky before you shoot a full wet coat otherwise you will get runs. Good luck
