ok so citroen relay van 52 reg 108k miles , yesterday decided to change the oil (done it a few times before no probs ) . Drained oil changed filter , refilled what i thought was the right amount ie about 4.5 litres (ok so i couldnt find the manual to check erxact amount
go to staart it and display says high oil level
, drain about a litre off . Try again still high , i say to myself wtf . check dipstick says ok !
Try to staart it turns over but not firing up
OK so display still says oil high , ok i will disconnect battery maybe that will clear the display and thus allow it to start .
REsult display cleared but still not starting
Well ok so in the end i phoned RAC guy came out this morning , didnt tell him about the over filled oil
, just that i wouldnt start ...
ok the result is air hose off and easystart sprayed into intake manifold , it starts
. He reckons its low fuel pressure or a sensor on fuel system .
Unfourtunatly tho im to the van hire place as it wont start without easysart even when warm
just seems bazarre its allways started no probs before now , dont see how high oil would fook the injection sytem
hope its not the ecu or anything too expensive ,
Bloody french /italian piece of poo , going for a vw or merc when its changed next year !
cheers mike
)go to staart it and display says high oil level
, drain about a litre off . Try again still high , i say to myself wtf . check dipstick says ok !Try to staart it turns over but not firing up
. OK so display still says oil high , ok i will disconnect battery maybe that will clear the display and thus allow it to start .
, just that i wouldnt start ...ok the result is air hose off and easystart sprayed into intake manifold , it starts
. He reckons its low fuel pressure or a sensor on fuel system . Unfourtunatly tho im to the van hire place as it wont start without easysart even when warm
hope its not the ecu or anything too expensive , Bloody french /italian piece of poo , going for a vw or merc when its changed next year !
cheers mike
at least its not a cosmo/powercraft / berlan ching chon clone
mike
