lesthegringo
New Member
guys, what tooling would I need to cut keyways into the bore of a part? I have the X2 mill and a 7 X 10 inch lathe, are there tools available that I could use with those?
Les
Les
is it just me or is the screen blank and there is no where to goIf money is no object these are the way to go.....![]()
If you have a four jaw you might be able to set it centre of the key way then use a end mill in the head stock? I did one recently and used a dermal to cut the key way out not as good a proper machining but it was only way I could do it!
