First of all this is my first post here so HELLO!
I've just wasted almost a whole day trying to get my friends Kemppi Mig welder to produce a decent weld, but i cannot get any penetration to my welds, Even after trying just about every combination of settings on the wire feed and current control.
I'm trying to weld car body panels, and had the welder working perfectly about a week ago, infact i was getting on so well with the welder i produced my first decent butt weld when repairing the door step on the mini. Since then not of the controls on the welder were touched (not knowingly anyway)
I seem to recall that i had the best results with the wire feed set around the 4 position & the Current set near 6. The welds were consistantly neat, penetration was good, then i try to use it today and cannot get a decent weld.
The welder in question is a Kemppi Super Kempomat, i'm not sure which model, it runs on single phase, its one of the older square syle ones, not of the new design with the angled control panel at the top as shown on the kemppi website. The wire fitted is 0.8mm & the gas is BOC ArgoShield, I'm not sure of the flow rate of the gas as the regulator fitted only tells you the cylinder pressure. I experimented a bit with the flow of the gas but it didn't make much difference to the weld produced.
I would have thought that if i turned the current dial to the maximum, the welder should easily blow holes in the thin 0.5-0.8mm steel used for body panels, but i goud not get more than a raised blob of metal that when given a tap with a cold chisel would just break off the parent metal.
Can any of you give me any advice on what might be the issue here? I am beginning to think that the welder is not working correctly.
