Triumphman
Hi all,
My husqavarna R216 slipped off the ramps and put a hole in the bottom case of the k46 transmission.
I removed it and had it welded, no problem so far.
As I took it apart a couple of parts came lose, so I followed a YouTube video of someone rebuilding this transmission and got it back together. Seemed fine.
Reinstalled it in the mower and now I have no drive, annoying.
There is a leaver on the left, as you look down which controls forward and back. This is moving freely.
There's another lever near this, which I believe takes it out of gear so the mower can be pushed, this is moving ok too.
There's a lever on the right which I'm not certain what it does.
I'm definitely not an expert on these.
Is there anything obvious I might have done wrong with the set up/cables etc which is preventing it from driving?
Don't want to have to drain and split the case again if I don't need to.
Thanks all
Thanks all
