Mick B
- Orange. NSW. Australia
While making my little log and axe today I drilled 2 X 3mm holes in the bottom of it before I started laying all the beads on it because the ends are capped off and I didn't want it to turn into a bomb with all the heat inside.
So lets say you cap both ends of a piece of 50mm pipe (with 3mm wall thickness) and don't have any holes drilled anywhere therefore making it air tight. With lots of weld beads there is going to be a lot of heat inside the pipe. Could this build up enough pressure to blow the pipe apart or would that only happen on say 1mm wall pipe?
