normspanners
As per title, bit annoyed really they gave good customer service calling to say its on truck, and was it easy for driver to get truck in to off load etc etc.
then they ring and say they cant find me, we are house names not numbers etc so I go out see him then direct him and also stopping traffic so as to back in to the drive which is easy 14ft wide, he totally ignored me and pulled up on the kerb opposite then proceeded to walk the fridge out of the stack, corner to corner, I could hear the compressor banging about in its housing then it was lowered on the taillift on a sack truck and run off the side of the taillift at speed so you have 100mm of tail lift then 100mm of kerb it bounced down at least 200mm instead of using the ramp at the rear of the lift. he said where do you want it I said leave it there I will move it in a little more gently. Fridges are quite delicate bits of kit with thin capillary pipes etc and the harshness of its ride I was more than concerned as to the possible damage it may have received.
if they handle them like that in front of you how are they handled back at the hub ??
-------trouble is its all BAD.
