Sounds like a feed problem to me using 0.8mm tips on 0.6mm wire isn't that bad. Maybe the liner is too big?
Can any welder be set up to purge with gas before and after pulling the trigger? i seem to get the odd time where i get porous starts and ends to welds, but not all the time.
Dan
Ah ok, mines just got a switch for the trigger, might see if theres any wires that can be swapped inside...!
Dan
Gas hose has been shortened to allow less use of gas to travel its way to the torch ( less line to purge).you're going to cry when you realise how much it's gonna cost ya with those disposables. Nice conversion though.
