Hi
This is my first post here so Hi to everyone.
I've been doing a Stage 1 MIG welding course at the local college as a starting point in deciding whether I can do some bodywork on my car.
It's a 10 week course, 2 hours per week and so far we've done pad welds and a T Fillet weld. I am lucky enough to be using a Kempi in my booth
, for voltage there is an A and B setting, then 10 stages on a stepless power dial. Wire is 10 stage stepless. We are welding 6mm steel together as it's easier (apparently
). The wire is 1mm.
We've had a video about the power/current (which I read as wire speed) and keeping them in the "working area".
Too high wire speed seems to want to try and back the torch off the piece and judders, too low seems to make a hissing sound with no crackle. Power seems to alter the heat and depth of penetration but speed of movement and closeness of tip seem to have just as much of an effect.
But there doesn't seem to me to be a big difference when settings are slightly too low and slightly too high.....
Anyway if you've got this far, here's my question....
Visually what shows me I am in the right power/current setting rather than just either side ? And IF the settings were perfect is there a way of visually telling its the technique that's off rather than the settings ?
Thanks very much
Paul
). The wire is 1mm. We've had a video about the power/current (which I read as wire speed) and keeping them in the "working area".
Thanks very much
Paul
