Quick question to those in the know. Fabricating the steel frame for the new workshop/garage and I’ve hit a small challenge.
The original plan was to have it 5.3 metres wide as the longest length of steel I have is 4880 (add the 10mm plates each end and the uprights at 203mm each. But that was going to waste almost a metre of potential width space which seems a shame.
So, rather than buy more of this UB (203x133x25.1kg) I was thinking about welding a bit on to the 3 horizontal beams to get them from 4880 to 5574mm. The plan was to butt weld the ends together and them weld a 8mm long plate in the web/gusset on both sides, but how long would that plate need to be?
These 3 beams will be holding the weight of a timber and felt roof which will sit on timber trusses so not a massive load. I just can’t find anything which will help me calculate this, probably cos it’s, ahem, less than desirable. Technically I think one is supposed to weld joining plates on the ends and then bolt them together.
