Hi All
I have an old, small, wood stove that I am trying to repair / rebuild.
The top and base are cast iron and circular. The tube between them is (was!) approx 1mm steel sheet rolled into a tube and riveted along the seam. Inside there is a fire lining which I have removed.
The tube and top/base were originally held together by just three rivets at each end, the cast iron has flanges for this.
The tube is approx 200mm dia by 300mm high.
I was considering joining the base and top to the tube by seam welding / or maybe tack welding. Will that work?
Maybe brazing would be a better idea?
No real strength required.
Any help / suggestions appreciated.
