Guineafowl
- Nairn
Perkins engine.
Plenty of coolant in it, but after prolonged work it sounds the buzzer and gives the coolant warning symbol.
Fan belt ok.
Slight play in the water pump bearing.
Radiator not too badly clogged but hard to get to.
Viscous fan reasonably easy to turn even when hot - is this right?
Rad seems full of hot water so probably not stuck thermostat (where is it?).
Plan is to blow out the rad carefully.
Any way of checking if the water pump is turning?
Fan belt ok.
