bought a 1990 JCB X3C a while back, runs great but I've had problems with the filter on the inlet to the fuel lift pump blocking with black gunk
think it's fuel bug
the glass bowl filter right after the fuel tank didn't have a filter inside it
I drained the tank, took the access panel off the tank, cleaned it out the best I could, swapped the glass bowl filter for one with a strainer/filter inside it, re-filled with fresh diesel and a good helping of diesel bug killer
but it's still blocking the lift pump strainer, I assumed it might block a couple more times while it was worked out of the system... but it's 4 more times now and it's getting old fast
does anyone know if I can fit a proper fuel filter between the glass bowl filter and the lift pump? or will that create too much restriction for the lift pump?
I could set a pump up with a diesel filter as a polishing system, suck out of the tank through the filter and back to the tank... but I can;t imagine that removing much when it's a pretty clean tank and fresh diesel?
think it's fuel bug
