Cornish301000
New Member
- Cornwall
Hi
I have the above machine which I am currently using 0.8 mm mild steel mig wire 5kg.
I want to weld some bases to mirror polished 316 stainless tubefor glass infill rail posts I will be setting the pipe slightly up the upstand on the base plate and welding the under side so not to get burn marks on the mirror finish.
My question is does anyone know if the machine will take a 1kg spool or can I buy a tig torch for the machine if so will it need to be a euro connector type.
I have tried looking in online instruction manual but l can not find any answers that are conclusive.
I thought about stick welding with 1.6 mm rods the wall thickness of the tube is 2 mm.
Thanks
Thanks
