vtechnician
Which of the 3 ingredients for 2k paint has the harmful chemical? Is is it the paint, hardener or thinner? Or combination?
your gun will be ok for celly
as for setting up your gun you need the real thing in it and each time you spray you will probably make slight adjustments to the gun anyway
i notice you did a test with water which really will tell you nothing as its very thin compared to paint
even if you get celly and practice it will still be different using 2k with celly you tend to chase the paint so as not to get dry lines / patches where as 2k flows a little after its applied so all paint is different.
if you will be using 2k the only way to practise is with 2k fully mixed
its like trying to weld using standard wire with no gas it just cant be done
in the interest of setting up my gun would paint + thinners do the job? Id like to see how the atomisation/over spray varies with pressure.
