Brad93
- Essex, United Kingdom
So I've had a bit of of trouble pressing together the shaft and sprocket combination.
17mm shaft.
Recommendation for bearings to be an interference fit was a shaft size of j5 tolerance = +2 to +5um. I thought that was a little loose so ended up at +7 to +9um.
Sprockets were heated to 150°C.
Bearings were heated to 110°C.
Bearings went on lovely with low pressure on the press.
Sprockets were bored to 17.01mm. Plus 10 microns. In my head I thought that was a good idea. I'm guessing this is where I went wrong.
What should my sprockets have been? Size of the shaft + tolerance?
Sprocket has galled the shaft slightly, it's not an issue to the final operation, but it's unsightly. Shame because it was all looking the mutts nuts.
17mm shaft.
