Guys..
is this tig machine any good?
http://cgi.ebay.co.uk/ws/eBayISAPI....ategory=113743&_trkparms=algo=LVI&its=I&otn=1
Its seems like a good deal for an AC/DC tig and plasma cutter in one.
Here is the spec
SUPER-160P
Power voltage Single phase AC230, 50/60Hz
Rated input current (A) 21
Power capacity (KVA) 3.3
Range of output 5-160 TIG 15-40 CUT
current (A)
No-load voltage (V) 62 TIG / 240 CUT
Working voltage (V) 16.4 TIG / 90 CUT
Up-slope time (Sec) 0-1
AC Clean width (%) 20-80
Down-slope time (Sec) 0-10
Pulse width (%) 10-90
Range of pulse current (A) 20-160
Range of pulse freq. (Hz) 0.5-200
Post-gas time (Sec) 1-10
Remote control YES
Arc-starting HF
Efficiency (%) 85
Max. weld thickness (mm) 0.1-6
Rate duty cycle (%) 60
Power factor 0.83
Insulation class F
Protection grade IP21
Weight (Kg) 23.5
Dimensions (mm) 520x330x375
I have the pdf spec sheet which lists the inverterfusion website but I cant find it on their site.
Amit
Here is the spec
SUPER-160P
current (A)
Remote control YES
Arc-starting HF
Efficiency (%) 85
Power factor 0.83
Insulation class F
Weight (Kg) 23.5
Amit
at IFL.
