I've got a cebora pocket 130 mig, I was trying to weld upside down yesterday at full power and I would find a heavy buildup stuck between the tip and the shroud. The tip would then have to be ground back to allow the wire through and the shroud would need cleaning up.
It doesn't help that my wire feed isn't the greatest thing in the world as it can get a little jerky and the burn back causes the wire to fuse to the tip.
Another thing is that when I'm pointing the torch into a corner for a fillet it doesn't tend to weld right into the corner. The arc would find anywhere other than the bit I wanted to weld! There's just no accuracy.
Yes I did clean both areas prior to welding and my co2/argon was set at 5lpm.
So am I doing something wrong or is it time to upgrade to a better mig?
