Specialist
Hi all, I'm a long time reader here so decided to finally join and post
I'm working as a welding specialist, well actually just got started on it, so I'm learning quite a lot, got to know the theory well, and working on practice. I have experience with MIG and welding altogether, but didn't work a lot with stick, so thats where I'm trying to improve. I have improved over the last few welding jobs, but, there's always room for improvement, and I'd like to master the stick.
I am using an Einhell AC welder that goes up to 160A, single and tri-phase powered (230V and 400V). As some of you would say, a buzzbox
But this one has fan cooling, and it didnt cut out on me even when burning 3.25 electrodes back to back for 10 to 15 min at about 120A.
Picture of the welder:
Specifications table:
So I have tried to join a few pieces I had lying around - first is a fillet join of 1 mm steel sheet, done with a 2 mm electrode type E 6013 at about 60A.
Fillet from behind, showing good penetration and some burn trough:
Fillet from the front, messy join and lot of slag inclusions, also spatter:
I tried to get it going, but it seems these particular 6013's (Jadran S) are not quite good, they tend to stick a lot, and either not penetrate and get slag inclusions, or to easily blow trough. Also, the slag is incedibly hard to chip off.
I tried capping it on a few places with ETC 3,25 mm E 6013, and had much better joining and flow of the metal then with 2 mm 6013 from another manufacturer (which I presumed would be better for 1 mm sheet). Altough it did blow trough on a few places, it was controllable with a little effort.
Coming to that, I bought a 4,5 kg box of ETC 3,25 mm E 6013 for about 10 euro, which is very cheap (read suspicious quality maybe), but turns out to be a very good electrode indeed, after some searching on the net I found out it is a probably licensed Oerlikon rod.
A couple of fast runs on 1 mm steel sheet with ETC 3,25 without blowing trough at around 110A:
Another look at the run, not too clean, but I would think acceptable:
And here is a clean drag run with ETC 3,25 mm on 10 mm steel at about 100A, there are two weld beads one next to other, 2 electrodes burnt:
Another look:
These were quite easy to strike, and it kept a nice steady arc all the way to the end, I'd say for the price it's good quality weld bead.
Here are a few rod tips remaining after welding
And here is the rod box, anyone seen these before?
Rod specs:
All in all they outperformed my expetactions for the price, really did not see that coming
Thanks for reading and taking time to respond, comments are welcome, especially about how to improve on that fillet.
Another look:
Rod specs:
