Wendelspanswick
I am curious on the best practice for doing a fillet weld with two internal corners?
With a pushing torch do you start in one corner with a negative torch angle, rotate the torch to the correct angle and push to the opposite corner.
Or do you push from the middle into the first corner and then start from the middle again into the opposite corner.
And the same question with MMA dragging a rod, start in a corner and end up pushing in the opposite corner or start in the corners and stop in the middle?
