tommullin
Hi guys,
I appear to have a very intermittent issue with my boiler. I have tried absolutely nothing and I’m all out of ideas. Honestly, I just thought someone might know some likely culprits I should check first before I get too deep down rabbit holes.
So I have only one rcd protecting every circuit, so if it trips, I have to drink warm beer and have a cold shower. I know it’s the boiler that’s causing the trip as that’s the thing that trips the rcd when I turn everything back on individually.
the rcd has tripped twice in the past few weeks (both times it was the boiler) and both times it wouldn’t reset for about an hour, then worked fine. After failing to reset a number of times (rcd kept breaking), waiting for about an hour and trying again, it all worked OK.
I was away in Australia for about a year and this never happened - I left the heating and water on low heat. I did have the same issue before I left, but it’s only started again since I’m back. I have increased the water and heating temp since I’m back.
I’m going to guess at a pump. But does anyone have any clues on where to start looking? I’m 17th edition and not an idiot, but not massively clued up on central heating systems. It’s an old glow worm micron system with a hot water tank and a switched off at the cu economy7 if that makes a difference?
thanks in advance!
thanks in advance!
