brnomauser
- Australia NSW
I'm hoping someone can make some suggestions for me. I'm getting air bubbles appearing in some of my welds. It's a MIG welder, I think 200A. Using straight CO2, clean wire. When I'm getting bubbles, it spatters and spits quite a lot and when I stop a little mountain grows out of the weld pool as it cools. When ground back it's very porous.
The thing is there is no pattern. I've searched and this seems to be a common problem when there is a lack of gas, contamination etc.. With me, it'll be fine one pass/side length, then on exactly the same piece of work it'll play up a lot. It doesn't matter if it's squeaky clean (verging on sterile), a bit dirty. Turning the gas up or down doesn't change it. The shroud is clean inside, there is nothing obstructing the flow. It seems completely random, some days it won't do it at all, other days I give up and use the arc or oxy.
Can anyone think of what might be causing this?
