But youll be fine as long as you wear eye protection! Because it seems you only need it parting off.Must admit that parting is my least favourite job on the lathe but, according to clough42 (or more accurately; his viewers), it's probably because I've been too wimpy...
I also broke my 2mm carbide bit holder, on both sides. And I began to use a larger holder with a 3 mm wide insert, intended for rougher work. Using a height gauge, setting the height of the tip of the cutter showed that I had previously been mistaken with the height and geometric center of the workpiece. I need to make a device for precise positioning (why not today?) and buy at least 4 more quick-change cartridges for cutters in order to adjust the entire set of cutters needed for the job without removing the knives for replacement. Unfortunately, Tripan cassettes, even used ones, are obscenely expensive and are rarely found in our area.Must admit that parting is my least favourite job on the lathe but, according to clough42 (or more accurately; his viewers), it's probably because I've been too wimpy...
Protuberance, nice word...I've adopted this approach also, with carbide inserts - as fast as you dare (+ maybe a little bit more).
Three things;
The protuberance of the parting blade is set to the minimum neccesary.
Make sure the parting tool is spot on perpendicular to the workpiece.
Once in cutting position, carriage locked.
Then stand to one side and hit the Y feed.
Always terrifying, but seems to work well.
The biggest mistake you can make when parting is to do it without any form of coolant.
It's a personal favourite, and I use it whenever I can![]()
I’m saying nothing…Although, on reflection I may have left myself open to pedantic enquiry (inquiry ?)
See if anyone picks up on it![]()
He says it’s 100m/min.He also needs to get things right. That is not 100 feet per minute surface speed! More like 260fpm - but only at the start of the cut - of course, surface speed is reduced towards zero as it cuts to zero diameter. His figure of 100fpm is for HSS, not carbide. Flooded cooling would be better.
