I've fitted CBR600 carbs to my 1.8 zetec using mild steel for a manifold
I used some 8mm plate for the flange that I chain drilled and filed (never, ever again), and mild steel tube MIG welded to it.
The most expensive bit was the silicone hose to join the carbs to the manifold. The whole lot was done for less than £50, luckily I already had a megajolt for sparks.
The difference between the old Weber carb and the bike carbs is night and day, all I've done to the carbs is drill the main jets out a bit and it's run beautifully over the last few thousand miles.
I've hosted a file with the Honda CBR workshop manual carb specific parts on my webspace, it came in handy when I was fettling
http://www.locost.pwp.blueyonder.co.uk/stuff/cbr600carbs.rar
(to say the least) i think i will stick with m/s - cant see the car still being on the road or having this engine long enough to rot through m/s
due to this not exactly being the flashest car ever(to say the least)
Sounds like my kind of car![]()
) have been looking at engines on ebay, i reckon i could get a 2.0 for 250-300 on there but it will involve a trip to england/scotland with the van. will have to have a ring round the local breakers
These are some sort of GSXR taper bodies, don't know which one though.
iain
the 750 K1 and K2 are identical to the 1000 K1 and K2 i beleive...
80mm spacing and taper from 42 to 48 mm......
also madzuki- the flange that those bodies are fitted onto.. does that bolt straight to the head??
from reading a few sites... the jenvey one especially i was lead to beleive that the distance from the valve face to the butterfly is as important as the distance from the butterfly to the open end of the inlet trumpet??
from jenvey site:
A practical minimum figure for a 7 - 9,000 RPM engine is 200mm,
